Some 100 six-axis robots weld, bond and package EV batteries at the FAW-Volkswagen Automobile Co. Ltd. assembly plant.
July 25, 2023
FOSHAN, China—Some 100 six-axis robots weld, bond and package EV batteries at the FAW-Volkswagen Automobile Co. Ltd. assembly plant here. The factory produces 300,000 battery packs annually.
The Digiforce 9307 monitors processes in which precisely defined functional relationships between two or more measured quantities need to be demonstrated.
LAVA is a Ukrainian-Canadian company founded in 1984 that manufactures in Canada. In 2014, LAVA shifted to designing and building hardware for adapters that can do power and data simultaneously to tablet devices, turning them into much more B2B accessible devices and conditioning their batteries to get about six years of life.
FRANKFURT, Germany—German suppliers of robotics and automation technology are forecasting record-high sales of 16.2 billion euros in 2023, an increase in sales of 13 percent. In 2022, the industry recorded sales of 14.3 billion euros, and increase of 5 percent.
According to an old saying, “what goes up must come down.” Unfortunately, that’s not true for either a helium-filled balloon or helium used in leak testing applications.
In most cases, finding a second source for commodity parts, such as fasteners, is fairly straightforward. However, the process is more complicated with adhesives,
REGENSBURG, Germany—BMW’s assembly plant here has become the first automotive factory in the world to use an end-to-end digitalized and automated process for inspection, processing and marking of painted vehicle surfaces in standard production.
Water heaters are one of the least glamorous types of home appliances. The vertical metal tanks typically sit out of sight in dark corners of basements or behind closet doors. Most homeowners never think about the devices—until there’s no hot water.
Roller bearings are a critical component of modern machinery. When the bearing is in operation, the cage must be able to withstand centrifugal force, shock and vibration, especially with complex loads rotating at high speeds.
