Airplanes old and new share many of the same types of components. One is a nacelle, or engine housing, with an inlet lip skin that ensures smooth air flow. However, not all planes have similarly shaped lip skins.
ABB has integrated the Baldor Electric Co. into its global brand as a part of its Next Level initiative. A member of the ABB group for more than seven years, Baldor Electric is now known as ABB.
Manufacturers KSM Log Homes Ltd. and AgJunction are located on opposite coasts of the United States and serve different industries. Nonetheless, they often face similar linear motion challenges with their equipment.
Every automobile requires a starter, and for decades, Bosch Auto Parts has been the world's leading supplier of this key engine component. The company manufactures starters around the clock on seven assembly lines at its plant in Hildesheim, Germany.
Speed, power and durability are key characteristics of industrial robots. These robots are typically used in applications such as welding or in lifting heavy components for vehicle assembly. Yet despite advanced calibration methods, the positional accuracy of industrial robots has been inadequate for certain tasks. This is now changing thanks in part to highly accurate, output-side encoders from Heidenhain and AMO.
As its name suggests, an inspection slitter rewinder (ISR) machine does many things - although not necessarily in the expected order. ISR machines made by Oakville, Ontario-based KOR Engineering Inc. are specifically designed to slit, laser perforate and inspect a wide range of pressure-sensitive labels, flexible packaging and shrink sleeves.
The "father" of the programmable logic controller (PLC), Richard Morley, recently passed away at age 84. After he invented the device 50 years ago, it revolutionized plant floors around the world. The PLC eliminated the need for hard wiring and spurred the development of flexible manufacturing.
Regardless of whether they are called drones or unmanned aerial vehicles (UAVs), their popularity is increasing among consumers, military leaders and institutions around the world. In fact, analysts at market researcher Teal Group predict that global spending on UAVs will reach $14 billion by 2024.
Manufacturers in many industries have relied on MESH Automation Inc.’s machine engineering, design and installation services for nearly 20 years. During that time, MESH has completed more than 850 projects of all sizes related to robotic workcells, vision inspection and system integration.
To handle simple material handling tasks in automated workcells, engineers typically opt for linear axes. However, assembling multiple linear axes into a Cartesian motion system can be a time-consuming process. You must connect each module to the next one, assembling subcomponents as you go, then wire each module, connect each axis to an external controller, and finally program the system.
