Since 1985, Staufermatic Maschinenbau GmbH has made a name for itself worldwide in two specialties. One is designing and manufacturing special-purpose machinery for assembly, riveting, drilling, leak testing, safety and press-fitting.
Airplanes old and new share many of the same types of components. One is a nacelle, or engine housing, with an inlet lip skin that ensures smooth air flow. However, not all planes have similarly shaped lip skins.
Numerous electrical-product manufacturers focus on making either AC inductors or DC power supplies. Micron Industries Corp. is one of a select group of manufacturers worldwide that produce both type of products, as well as transformers, reactors and fuse panels.
For 50 years, progressive-die-stamping specialist Trans-Matic Manufacturing Inc. (TMMI) has stayed focused on producing affordable, high-quality parts for its thousands of customers.
Manufacturers KSM Log Homes Ltd. and AgJunction are located on opposite coasts of the United States and serve different industries. Nonetheless, they often face similar linear motion challenges with their equipment.
Every automobile requires a starter, and for decades, Bosch Auto Parts has been the world's leading supplier of this key engine component. The company manufactures starters around the clock on seven assembly lines at its plant in Hildesheim, Germany.
Ralph Braun showed the world his many abilities over many years before dying in 2013. Born in 1940 and diagnosed with muscular dystrophy at 6 years old, Braun created a motorized wagon less than a decade later to help him get around. In 1962, he built a motorized scooter, which he called the Tri-Wheeler, and rode it to and from his day job as a quality control manager for a nearby manufacturer.
Like every niche assembly process, manufacturing cables for industrial equipment presents numerous challenges. One of the most common is being able to consistently print clear markings on each cable.
