When the HVAC industry converges on Atlanta for AHR Expo 2019, attendees can expect to see manufacturers showcase products aiming to be both smarter and more efficient—automation and connectivity will continue to drive home and commercial innovation, and components throughout the trade floor will aim to keep pace with federal regulations.
In the early days of air transport, pilots relied on a nationwide network of beacons for night time navigation. A hundred years later, the first generation of autonomous vehicles may also rely on light beams to navigate safely.
DEARBORN, MI—Engineers at Ford Motor Co. are developing car parts made out of graphene, a two-dimensional nanomaterial. Graphene is 200 times stronger than steel and one of the most conductive materials in the world.
DULLES, VA—Airbus and Northrop Grumman Corp are partnering to develop next-generation composite manufacturing technology. The three-year Wing of Tomorrow program will explore complex composite wing stiffener forming automation and out-of-autoclave material systems.
ZUFFENHAUSEN, Germany—Engineers at Porsche are setting up a new type of assembly line at its factory here to build a new type of sports car. The all-electric Taycan will be assembled in a “factory within a factory” as part of the Porsche Production 4.0 initiative.
Auto-Kabel, the global automotive supplier, manufactures cable and lead sets for power supply applications. The friction welding machines deployed in the process must always have an adequate supply of material without excessive safety stocks.
Companies measure success in several ways. One of the most important measurements is their number of repeat customers. For wire harness shops, the best way to gain repeat customers is to provide them an ongoing supply of harnesses that are high quality, economical and specifically designed to meet each application challenge.
Faced with the need to join aluminum to aluminum and aluminum to steel, automakers have been forced to find alternatives to the tried-and-true spot welding technology they had been
using for decades to join all-steel assemblies. Flow drill screws are one such alternative.
The principle of shielding is creating a conductive layer completely surrounding the object you want to shield. This was invented by Michael Faraday and this system is known as a Faraday cage.
