Assembly Magazine
LeakMaster, Inc. UltraFlow V3 Leak Tester
LeakMaster
LeakMaster is excited to announce the release of our latest leak testing technological advancement. The LeakMaster UltraFlow V3. The V3 Mass Flow and Pressure Decay leak testing instrument is specifically designed to quickly test large components such as automotive/diesel emission systems, plastic reservoirs, automotive lighting assemblies and Hybrid battery packs. Speed and accuracy are the hallmarks of this exciting technology.
The UltraFlow V3 incorporates many unique industry driven features, including a 64bit ultra-speed processor and 7” high resolution touch screen for easy set up and navigation. The V3 instrument comes standard with electronic pressure regulation. This powerful feature allows the user to select a specific test pressure for the application without needing to adjust a manual regulator. Our enhanced digital Mass Flow and Pressure Decay sensors provide a wide 1 CCM to 300 LPM testing range giving the user ultimate testing flexibility. Enhanced Ethernet IP communications provides ease of integration, ultimate control, faster startup, and effortless extraction of test results. Our exclusive “slave mode” enables the user to transfer program recipes remotely via Ethernet IP. The intuitive internal data collection stores all pertinent data for ease of viewing including program times, limits and final leak rate information. Test results can be easily extracted via network connection or USB flash drive. The V3 UltraFlow compact size and dual access doors provide flexible mounting options. The LeakMaster V3 UltraFlow, the most powerful, flexible leak testing instrument on the market today.
For more information on LeakMaster Leak Test Instruments, Contact (812) 437-TEST https://leakmasterusa.com or email sales@LeakMasterusa.com
