From October 24 to 26, 2017 at The ASSEMBLY Show in Richmont, IL, Eisele Connectors presents a range of durable solid metal connection components for compressed air, gases and liquids, that are ideal for use in rough environments and industrial assembly processes. Eisele Connector’s INOXLINE represents an extensive line of different stainless steel solid metal push-in connectors with an easy-to-handle release sleeve. These non-corroding and easy-to-clean connection components are the ideal solution for rough industrial environments and aggressive media. Smooth surfaces and a special design prevent dirt, weld spatter and other residues from accumulating and facilitate handling and exterior cleaning. The material used is stainless steel AISI 304/304L or AISI 316L on request. All parts are crafted from solid material and are ideal for rough or corroding applications in all branches of industrial manufacture. Due to the large range of high-quality sealing materials, including Viton and FFKM, suitably designed push-in connectors of the INOXLINE can be used at temperatures from -58 °F to +392 °F. INOXLINE also includes stainless steel push-in connectors designed without dead spaces or joints where product residues can accumulate. They are ideal for paints and enamel varnish.
Corrosion-resistant compressed air distribution
Eisele INOXLINE push-in connectors are designed for rough environments and durability
Eisele Connectors Inc. is a subsidiary of Eisele Pneumatics GmbH & Co. KG, which emerged from a company founded in 1939. With more than 75 years of experience in precision machining, Eisele is one of the world’s leading suppliers for high quality all-metal connectors and in developing customized connector solutions. Drawing from the company’s proven German manufacturing expertise, Eisele’s North American facility keeps an expansive stock of products and can optimally supply its customers and respond quickly to fulfill needs. The company is part of a global logistics network that guarantees fast availability of products to the global market and is a member of the American Welding Society (AWS), the Society of Automotive Engineers (SAE), the Society of Manufacturing Engineers (SME) and the Association for Hose Accessories Distribution (NAHAD).
