At The ASSEMBLY Show from October 24 to 26, 2017 Eisele Connectors presents the BASICLINE, a range of more than 3,500 standardized types of pneumatic connectors for compressed air, vacuum, gases and fluids. All pneumatic connectors are made of high-quality materials. Eisele Connectors fufills most tube connection tasks for pneumatics, vacuum, gases and liquids with one of its most successful product lines: the standard connections and throttle valves of Eisele BASICLINE. The time-proven push-in fittings with a release sleeve, as well as accessories and a wide variety of high-grade tubes are available with NPT, R and G threads. The threads feature an FDA-compliant PTFE coating with PU content. In addition, G threads are available with an enclosed O-ring or VS seal ring. The BASICLINE is designed for convenient connection and disconnection of tubes in assembly processes for all industrial branches. The function of the robust and durable release sleeve is not impaired by impurities or rough environmental conditions.
Eisele Connectors at the ASSEMBLY SHOW-The best choice for compressed air
Eisele Connectors supplies solid metal connections for industrial assembly processes.
About Eisele Connectors: Eisele Connectors, Inc. is a subsidiary of Eisele Pneumatics GmbH & Co. KG, which emerged from a company founded in 1939. With more than 75 years of experience in precision machining, Eisele is one of the world’s leading suppliers for high quality all-metal connectors and in developing custom connector solutions. Drawing from the company’s proven German manufacturing expertise, Eisele’s North American facility keeps an expansive stock of products and can optimally supply its customers and respond quickly to fulfill needs. The company is part of a global logistics network that guarantees fast availability of products to the global market and is a member of the American Welding Society (AWS), the Society of Automotive Engineers (SAE), the Society of Manufacturing Engineers (SME) and the Association for Hose Accessories Distribution (NAHAD).
