Are your leak rate specifications beneficial? From a technical standpoint, we often see challenging requirements that are simply unnecessary. Extremely low thresholds are a major cost-driver in quality assurance. Our experience shows that such limits are not always necessary for the selected applications, therefore we will provide a more cost-effective solution. If you could reduce your specifications and change the test method from helium based testing to air, you could potentially save thousands of dollars a month. For example, the investment for a helium leak tester is considerably higher compared to equipment that uses air. In addition, the operating costs are extremely high due to the use of special gases. Using our vast experience to analyze and evaluate your existing test scenario, we are able to recommend the most cost-effective solution for your test requirements, without compromising rigorous technical standards. Not only do we provide a wide range of high-end leak testers, but we also provide our vast leak testing experience to ensure optimal solutions for your measuring challenge. Our devices offer benchmark accuracy and have best-in-class measuring capabilities. Our team of highly experienced engineers have the ability to design your specific parameters, as well as providing the integration of process automation where necessary. If you are looking for an unmatched solution, come visit ZELTWANGER Leak Testing & Automation at booth 1616, where German engineering meets American ingenuity.
ZELTWANGER Leak Testing & Automation | Booth 1616
ZELTWANGER Leak Testing & Automation is bringing a wealth of German engineering expertise to the U.S. We provide competent advice, sell advanced technology, and develop custom solutions.
ZELTWANGER Leak Testing & Automation LP | 4947 Fargo Street |North Charleston, SC 29418 | 843-225-0571 | contact.lta@zeltwanger.com
