DIW Series feature drive-centered torque sensors that deliver consistent readings no matter where the wrenches are gripped and load applied. Extend any length for easier torque tightening or loosening and readings remain consistent because the torque sensor is centered on the drive instead of in the handle. Tightening or loosening breakaway tests up to 35 lbf-in. can be used to evaluate fastener tightening torque. Torque-controlled wrenches can also be evaluated by comparing torque on a given fastener using breakaway tests. DIW wrenches are ultra-accurate , ±0.5%, ±1 LSD, F.S. and have High/Low programmable setpoints with audible beep and LED indicator for uniform tightening and Go/No Go testing. Peak and continuous data can be downloaded via the USB virtual COM port. The testers are rugged enough to be used in production environments and powered by rechargeable NiMH batteries or the included AC adapter/charger. Other DIW wrench models measure up to 1040 lbf-in. • Ultra Accurate ± 0.5% F.S., ±1 LSD • 300° Rotating Head adjusts viewing angle • 800 Data Memory recall data on the display or download • Output Data USB virtual COM port sends peak or continuous data • Rechargeable internal NiMH batteries (8 hour use) and AC Adapter • Programmable High/Low setpoints with audible beep and LED indicator • Peak, Real Time, Breakaway and Continuous Output modes • Selectable units: lbf-in, kgf-cm, N-cm and N-m • Statistics: number of data, Max, Min, Avg • Screw Tightening Counter • Auto Zero Reset, Auto Shutoff • Kit includes carrying case and AC adapter/charger (CW one-way clutch is included with DIW-4W/15/20 and available as a separate item for DIW-75 and DIW-120).
New Digital Torque Tester/Wrench Model DIW-4W
DIW Series of digital torque testers/wrenches adds a new 35 lbf-in capacity wrench with 1/4" square drive.
Imada, Inc. 3100 Dundee Rd., Suite 707, Northbrook, IL 60062 Tel: 847-562-0834 Fax: 847-562-0839 https://www.imada.com E-mail: imada@imada.com
