Schleuniger, Inc., a leading international manufacturer of high-precision wire processing machines, will be exhibiting at The Assembly Show, an assembly focused trade show aimed at helping suppliers, buyers and users of assembly equipment in manufacturing plants connect, learn, share and explore all things assembly. This exclusive showcase will be held October 24-26, 2017 at the Donald E. Stevens Convention Center in Rosemont, IL. Schleuniger will be at booth #231 providing hands-on demonstrations of innovative solutions for stripping, cutting, crimping and marking all types of wire and cable. New for 2017, Schleuniger will demonstrate its latest pre- and post-processing machines, the PreFeeder 3200 and CableCoiler 1450. The PreFeeder 3200 is a puller type prefeeding machine for wires and cables with an outer diameter of up to 35 mm (1.37”). Made for use with Schleuniger cut and strip machines, this economical prefeeder provides constant tension to the downstream wire processing machine. The new CableCoiler 1450 offers fully synchronized, precise wire and cable coiling and is compatible with all Schleuniger cut and strip machines. In addition, for the first time at The Assembly Show, Schleuniger will demonstrate the Laser Wire Solutions Mercury-4 laser wire stripping machine running as part of a full in-line wire processing system. This in-line system is the perfect solution for stripping shielded twisted pair cables. The Mercury-4 provides guaranteed nick-free stripping with radial and axial incision capability. The in-line system, which can be controlled via Cayman software, processes wires and cables up to 6 mm (.236”) O.D. and can perform virtually unlimited length end strips or window strips. Also new in laser technology, Schleuniger will be demonstrating an in-line system featuring a laser wire marker from Tri-Star Technologies. The Tri-Star Laser Marker, which is fully integrated with Schleuniger Cayman software, can be run in-line with a Schleuniger cut and strip machine and can apply marks anywhere along a wire or cable. The machine prints in any font, size, and orientation and can mark any UV laser markable wires, including Kapton, Tefzel, and Teflon insulated wires and cables. Schleuniger will also showcase equipment from Exmore, a worldwide equipment supplier in wire, cable and connection technology. Schleuniger will demonstrate the Wire XL Multi Connection Machine. This high-performance machine with programmable features has been developed for special applications in connection technology. The Wire XL is distinguished by the constant quality of the connection process. Its user-friendliness and modular set-up make this system an excellent production tool. In addition, Exmore’s Un-Twister will also be shown. This semi-automatic un-twisting machine offers high production efficiency in combination with perfect processing quality. It is easy to operate, attractively priced and guarantees accurate performance. Many additional products will be demonstrated, including the CrimpCenter 36 S, MegaStrip 9650, MultiStrip 9480, EcoStrip 9380 and StripCrimp 200 as well as equipment from the UniStrip line of wire stripping machines and CoaxStrip line of coaxial cable stripping machines. More information can be found at http://www.schleuniger-na.com/assemblyshow. Should you have any questions, please e-mail sales@schleuniger.com or call (603) 668-8117.
Schleuniger, Inc. to Exhibit New Wire Processing Equipment at The Assembly Show
![IAI](http://www.assemblymag.com/ext/resources/Events/TAS/press-releases/schleuniger.png?1547045945)
About Schleuniger The Schleuniger Group in Thun is a globally active technology company and a leading supplier in the Wire Processing industry. Customers of the Schleuniger Group primarily supply the automotive, entertainment, and information industries as well as the communication sector. Schleuniger products are used whenever precise wire processing plays a role. Development and production are located in Switzerland, Germany, and China. Schleuniger is always close to its customers - with four Sales and Service companies in the US, Germany, China, and Japan as well as with 40 distributors worldwide. The Schleuniger Group represents the Business Unit Wire Processing of the listed Metall Zug Group and has about 640 full-time employees and 30 trainees worldwide.
