2019 New Product of the Year Award Winners
At The 2019 ASSEMBLY Show a total of 20 products were nominated across five categories. Check out the incredible 2019 New Product of the Year category winners below!
Category #1: Assembly Machines & Systems
2019 WINNER
Linear-Motor Conveyance System for High-Speed Assembly
Booth: 313
The SuperTrak Micro is a linear-motor-based conveyance platform that enables the creation of flexible and high-speed production systems. Its unique merge-and-divert technology allows manufacturers to fundamentally change the way an automation cell is designed. Built on the SuperTrak Gen3 foundation, the platform combines individual shuttle control with high-speed sort-and-divert capability. With payload of 1.5 kilograms per carrier and a part spacing as low as 50 millimeters, this platform is ideal for small-part assembly. Modular components within the platform let designers configure a process before determining the final product, making it perfectly suited to high-mix applications. The platform is versatile enough for manufacturers to adapt to market conditions and meet customer demands—whether the task is to build 1 million batches of one, or one batch of 1 million.
ATS Automation Systems Inc., www.atsautomation.com, 519-653-6500
Category #2: Adhesives, Dispensing & Curing
2019 WINNER
3D Printed Disposable Mixing Nozzle
Booth: 2150
Re Mixer I is a disposable mixing nozzle that mixes two-part adhesives in less than half the length of existing options. This means half the adhesive waste, increased operator dexterity, and greater positional accuracy in automated meter-mix systems. The mixer is produced with advanced 3D printing technology. Recursive computer simulation was employed to derive its unique shape.
Re Mixers Inc., www.remixers.com, 847-340-7103
Category #3: Fastening Tools
2019 WINNER
One-Handed Nutrunner
Booth: 331
The EABS right-angle nutrunner enables an assembler to tighten fasteners in cramped spaces with one hand, so he can use the free hand to support himself or hold other components out of the way. For greater versatility and comfort, the tool is battery powered, ergonomically designed and weighs just 2 pounds. It is 11 inches long, tightens fasteners up to 24 newton-meters and can run at more than 1,000 rpm. To further boost productivity, the nutrunner can be paired with the company’s wireless Connect smart hub for applications where traceability is essential. Pairs in seconds.
Desoutter Industrial Tools, www.desouttertools.com, 877-224-7377
Category #4: Robotics
2019 WINNER
Six-Axis Robot
Booth: 431
Economical and easy to install, the VT6L six-axis robot is ideal for a wide range of simple parts-transfer applications. These include machine-tool and injection molding loading and unloading, pick-and-place, dispensing and assembly projects. The robot’s built-in controller saves on valuable factory space, while its SlimLine design features a compact wrist pitch that enables access to hard-to-reach areas in confined spaces. In addition, the robot has a reach up to 900 millimeters, a payload up to 6 kilograms and a hollow end-of-arm for simplified cabling and versatile tooling. The robot works off 110- or 220-volt power, installs in minutes and its encoder requires no battery, reducing the overall cost of ownership. Integrated vision guidance is optional.
EPSON Robots, www.epsonrobots.com, 562-290-5930
Category #5: Factory of the Future
2019 WINNER
Wearable Bar Code Scanners
Booth: 2100
MARK Basic and MARK Standard Range are work gloves equipped with matchbook-sized bar code scanners. Because workers don’t have to constantly pick up and put down handheld scanners, the gloves save up to 4 seconds per scan. MARK Basic has a scanning range of 5 feet. It can be quickly hooked up to a corporate network via Bluetooth Low Energy (BLE) and comes with a “worker feedback” option. Through optic, acoustic and haptic alerts, workers know immediately if they have picked the right item. The device can scan 3,000 codes per charge. The MARK Standard Range lets users scan bar codes at a distance of up to 32 inches. It can scan 6,000 codes per charge. It is ideal for high-frequency scanning environments, such as assembly lines.
ProGlove, www.proglove.com, +49-151-4214633
