Laser welding is one of the newest technologies for joining thermoplastic parts. This noncontact process has many advantages. It’s fast and precise, and it doesn’t generate flash or particulates.
High-efficiency ballscrews are ideal for precise, high-speed linear positioning. However, back-driving can be an issue, especially if the ballscrew is in a vertical position. If the ballscrew is not held properly, the load could drop quickly and cause damage to the payload, machine and workers.
The loudspeaker market is booming. In addition to designing to an outstanding product, efficient production is crucial for a speaker manufacturer to stay ahead of its competitors. Adhesives play an important role in this, but the potential they offer for increasing productivity has yet to be fully realized.
Construction equipment, farm tractors and other off-highway machines need more than just diesel engines, big tires and metal tracks to operate. They require hydraulic mechanisms to steer, raise booms, open buckets or tilt blades.
No matter which method is used, the goal is low production costs and a quality end product.
October 1, 2016
Design engineers consider a number of factors when deciding which joining method is best suited to a particular application. Each has pros and cons, and this article will look at some of the reasons behind the choices for one over the other.
Walk into any modern assembly and packaging facility, and the conveyor systems may very well resemble roller coasters at an amusement park—going up steep inclines, moving down drops, and twisting and turning around equipment and machinery as they transfer product from one area of the plant to another.
High-tech adhesives are very reliable, and problems do not occur often. When used correctly, adhesives can resolve many design issues while also saving money, time and effort.
Quality and innovation have been the name of the game at Club Car ever since the company was founded in 1958. Today, the company produces 40 base models of golf, utility and transportation vehicles.
Incompatible thermoplastic polymers can be welded by using polymer blends that are compatible with both components.
September 8, 2016
Ideally, every component in a plastic assembly would be made from the same material. However, cost, functional and aesthetic requirements often dictate that a mix of materials be used.
