Commercial protocols in aerospace applications present designers with the challenge of balancing the standard against the special needs of the application.
Going with the flow of the marketplace not only makes sense for a manufacturer, it can also make the company lots of money. An equally beneficial strategy—implemented on an application-by-application basis—is to know the flow of each material being dispensed and equip accordingly. Electronics contract manufacturers are well aware of the benefits of both practices.
Most people associate additive manufacturing with plastics. However, a slew of new materials and processes are now available that enable engineers to print a variety of metal components.
Once you’ve had an opportunity to review plastic part assembly and joining options, you can finish out the selection process with some guidelines in mind.
July 1, 2017
Plastic welding isn't one technology - the term encompasses a range of joining technologies that continue to evolve to meet a wide range of assembly needs.
The simplest approach from a refrigeration system design perspective is to use a single evaporator coil.
July 1, 2017
A common domestic refrigerator consists of medium and low temperature sections. The challenge for the system designer is to find cost-effective solutions to properly control the temperature and humidity for both sections in an efficient manner.
For many modern consumers drawn to nostalgic gems like physical books, vinyl records, and Polaroid cameras, there's something comforting and cool about going retro in the digital age.
During a recent visit to this bright, open, state-of-the-art factory, I took a turn on the line assembling one of DEWALT’s hottest products, the 20-volt MAX XR three-speed cordless drill and screwdriver, which is powered by a brushless motor and a 5 amp-hour lithium-ion battery.
The main objective for manufacturers of commercial transportation equipment is to profitability build high-quality products. One way to meet this objective is to assemble trailers and truck bodies with advanced structural adhesives and seam sealers.
