SOUTHFIELD, MI–Lawrence Technological University unveiled its new Siemens Electro-Matic Industrial Engineering Laboratory at ceremony this month. Siemens Corp, a subsidiary of Siemens AG, was also honored as LTU’s Corporate Partner of the Year.
Today’s manual torque wrenches and screwdrivers collect more data and transfer it wirelessly, providing greater assurance that each threaded fastener is accurately tightened
Whenever the 1920s are discussed in documentaries, they are first referred to as roaring and then as depressing. Too often, too little attention is paid to what happened in between these two extremes.
Engineers are challenged daily to come up with economical product designs that reduce weight, size, raw materials and labor. This competitive mandate affects every design facet, including the fasteners needed to hold components in place.
For basic welding jobs, companies often rely on blueprints, tools and tape measures to build and weld the parts. However, when using these conventional tools, there's a high risk of mistakes being made and, at the end, having to break the parts loose, which is expensive and time consuming.
Robotics and wrestling have a lot in common. Flexibility and reach are important to both. Robots and wrestlers also have numerous categories that are based on different weight and payload capacities.
Manufacturers in agriculture, mining, petroleum and other industries rely on centrifugal slurry pumps to move thick, particle-filled liquids. These heavy-duty pumps feature a rotating impeller that uses centrifugal force to move water and solids through pipelines over short and medium distances.
Whether it's a car or a computer, a toy or a toaster, almost every assembled product has at least a few threaded fasteners. Indeed, 62 percent of ASSEMBLY's readers use threaded fasteners of one form or another to assemble their products.
