The Coiled Spring Pin was invented by Herman Koehl in 1948. Easily recognized by its unique 2¼ coil cross section, Coiled Pins are retained by radial tension when installed into the host component, and they are the only pins with uniform strength and flexibility after insertion.
Rotary indexers for automation applications offer a high degree of flexibility and performance. As you'll discover, if applied correctly, WEISS rotary indexers can operate at peak performance and output for many years with minimal maintenance and virtually no adjustments.
Rotary indexing table use is widespread in automated assembly machinery and selecting the proper mechanism is essential for both maximizing performance and minimizing the cost of this critical component.
Work instructions (WI) in the past and present are typically printed on paper and many times do not represent the current processes on the plant floor.
Rapid change has become the norm in today's marketplace. With it comes even greater pressure for new technologies to accommodate manufacturing needs to fulfill the consumer demand now and in the future.
Pneumatic power tools are commonly used across a wide range of industries and applications. For many, they are a critical part of the manufacturing process.
