New Process Improves Copper Wire Conductivity Austin Weber January 2, 2024 Adding a small amount of solid carbon to copper can boost its ability to conduct electricity. Read More
Processing High-Voltage EV Cables Nick Liu December 14, 2023 Applicators, crimping machines and other types of high-voltage cable and wire processing equipment play key roles in electric vehicle production. Read More
Wire Processing Harness Tester Indicates Distance to Short or Break October 13, 2023 The CableEye cable and harness test system can now show engineers the distance to a short in addition to the existing distance-to-break capability. Read More
Wire Processing Automotive Ignition Parts October 13, 2023 ETCO has introduced a full line of standard automotive ignition components. Read More
Wire Processing Metal Hoods With M25 Angled Cable Entry October 13, 2023 The wide range of 21.21 rectangular connectors offers a number of advantages for modern industrial applications. Read More
Wire Processing Comfortable and Safe Ferrule Crimping October 13, 2023 The PZD 16/R and PZU 16/R crimping pliers are used for precise and safe attachment of ferrules to conductors according to the DIN 46228 standard Read More
Wire Processing Electrical Insulation Tape for EV Batteries John Sprovieri October 13, 2023 Volt Tough electrically insulative, single-sided filmic tapes are engineered to address the challenges of insufficient electrical insulation in EV battery packs. Read More
Wire Processing Software Supports Wire Prep for Panel Assembly René Lehn October 12, 2023 Automation helps German machine builder produce control panels quickly.Read More
Digital Systems Will Help Reduce ‘Cable Clutter’ in EVs Austin Weber October 2, 2023 A new R&D project called Next2OEM is tackling the challenges of mass-producing wiring harnesses. Read More
High-Strength Aluminum Wire Helps Address Lightweighting Austin Weber September 1, 2023 Engineers at LS Cable & Systems Ltd. recently developed a new high-strength aluminum wire that boasts an enhanced strength over traditional materials.Read More
