If humanoid robots could talk, they would readily admit that their real-world capabilities are much more limited than those showcased in movies and TV shows.
Manufacturing high-quality parts is no longer the only measurement of success for Tier 1 automotive suppliers. Reliable part traceability—from preassembly until the end of its wear life—is equally important.
At the Automate trade show in Chicago last week, the exhibit hall was buzzing with talk about collaborative robots. The next-generation machines allow robots to operate side-by-side with humans on assembly lines.
Welded plastic cylinders are the lifeblood of British manufacturers Harvey Softeners Ltd. and Wavin Ltd. Harvey produces pressure tanks for its water softeners, while Wavin makes plastic tubes that connect to below-ground drainage systems.
Hard at work within Shelbourne Rey-nolds Engineering’s Suffolk, UK, manufacturing plant are nearly 100 assemblers and the latest equipment to build attachments for articulated hedge cutting tractors.
