PALMDALE, CA—Northrop Grumman Corp. has delivered the first F-35 center fuselage produced by its Integrated Assembly Line (IAL). The IAL maximizes robotics and automation, providing additional capacity and assembly capability while meeting engineering tolerances that are not easily achieved using manual methods.
Eaton Corp. produces more than 1 million engine valves per day for nearly every automaker and engine manufacturer in the world. One of the company’s largest manufacturing facilities, located in Kearney, NE, supplies highly engineered valves that increase fuel economy, improve efficiency and boost performance.
CLEVELAND, TN—Procter & Gamble Duracell will invest $36 million over the next three years in its two assembly plants here, create 60 to 80 additional jobs.
SCHAUMBURG, IL—Many motion control applications such as machining spindles and scanning equipment require more than just position values from the motion feedback device. It is also imperative to know what velocity the axis is running, as there may be a need to control the velocity from one speed to another rapidly, or to maintain a constant speed because other operations and triggers need to occur based on the constant velocity.
