ROCKY HILL, CT—More than 40 Loctite distributors across the country will hold open houses this fall to highlight their newly updated equipment showrooms.
The latest generation of pressure-sensitive adhesives and converted materials offer great potential for product improvement. They hold the key to better product performance, greater manufacturing efficiencies, better staff utilization, and ultimately across-the-board cost reduction.
CARLSBAD, CA—Systems integrator Automation GT has built a multistation automated assembly system to make syringes. Designed for use in a Class 10,000 clean room, the system includes robots, vision systems and dispensing equipment.
A variety of high-tech equipment is available to dispense two-part adhesives.
July 1, 2013
Dispensing a one-part adhesive is easy. You only have to worry about the viscosity of the material, the flow rate, and how you want the material to be applied to the part.
The new coating produced a log 5 reduction on 14 common microorganisms.
July 1, 2013
The conformal coating Parylene has long been known for its excellent dielectric strength, high thermal stability (up to 450 C), dry-film lubricity and outstanding chemical resistance. Those properties have made the material a staple for coating printed circuit boards and electronic devices exposed to environmental extremes.
Steel is not about to disappear anytime soon as the dominant material used in the home appliance industry. Unlike automakers, which are turning to aluminum, carbon-fiber composites, magnesium, plastic and other lightweight materials, steel still rules in the world of refrigerators, dishwashers and dryers.
Initiating movement of a standard bicycle can sometimes be challenging, such as when peddling up steep hills. Initiating movement of an electric bicycle, on the other hand, has always been much easier. The rider either pedal-assists the motor or activates it with a throttle.
