With pumping speeds ranging from 80 to 800 liters per second, the HiCube Neo vacuum pumping station is ideal for demanding high vacuum and ultra-high vacuum applications.
BUILT’s welding tables have a base height of 36.5 inches. High-performance actuators raise and lower loads 12 inches at the touch of a button, for smooth, ergonomic operation
By helping its customers access open, easy-to-use automation based on intelligent robots that are flexible enough to dynamically adapt to changes in the production environment, Comau is helping transform the Power of Automation for industries of all sizes.
In 1982, Honda opened a new assembly plant in Marysville, OH, becoming the first Japanese automaker to operate a factory in the U.S. Now, big changes are coming to this historic plant.
