The JacketStrip 8310 precisely slits the outer jacket of insulated cables. Due to the unique floating blade system, round or out-of-round cable jackets can be processed without damaging the cable layers beneath. Radial and axial slits can be performed to facilitate jacket removal in a secondary manual operation. Simple operation, short cycle times and a universal blade design provide a good return on investment.
A rotating blade, which precisely follows the surface of the jacket, ensures precise radial slitting of the jacket. Optionally, the cable jacket can be slit lengthwise while extracting it from the machine. After the slits have been made, the insulation jacket can easily be removed by hand. The machine can process cables from 0.1 to 1 inch OD and up to 19.7 inches in stripping length without any damage to the inner conductors or shielding. No blade changes are required. Programming is done via a color touch-screen. A digital display shows axial and radial blade depths.
Schleuniger Inc.
www.schleuniger.com
