Fogging lenses can strike in both indoor and outdoor working conditions. Spectrum safety glasses have options to fight fog no matter where work has to get done. This powerful ANSI Z87.1+ eye protection weighs less than 1 ounce, and the rimless lenses are manufactured with exclusive BK-Anti-FOG protection. Spectrum pops with color, too, as each lens color in the family sports a unique, corresponding temple color.
Temperature changes, humidity, sweat, rain, and moisture all contribute to lens fog. Spectrum Clear Lens allows maximum light transmission, indoors or out, without changing or distorting vision or colors. Spectrum Smoke Lens provides all-over tint for normal outdoor conditions (18 percent of light passes through). Amber, blue, and mirrored lenses are also available.
BK-Anti-FOG lens protection lasts 15 times longer than EN 166/168 standards. The special coating is permanently bonded directly onto the lens surface and will not wear off or wash off. Glasses retain fog-fighting properties for a longer duration with no reapplying and no maintenance needed.
Bowed, super-flex temples touch the wearer only behind the ears, eliminating all pressure points while delivering the optimal fit. The ratcheting flexible temples and second-generation PivotEase nose piece offer a true face-hugging design that inspires compliance. Spectrum lenses are also anti-scratch, anti-static, and UV protected.
Brass Knuckle
www.brassknuckleprotection.com
