New & Noteworthy
Dispensing System for Two-Component Materials
Photo courtesy of Techcon
The TS8200D Series Micro-Meter Mix Dispensing System is a precision volumetric mixing and dispensing system for two-component adhesives, such as epoxies, reactive acrylics, or polyurethanes.
The system consists of two newly updated M-Series progressive cavity (PC) pumps integrated into a fluid manifold and connected to a static mixing nozzle. This configuration enables software-controlled mix ratio configurations from 1-to-1 to 10-to-1, achieving accurate and repeatable dispensing results.
“Techcon’s TS8200D Micro-Meter Mix is the natural evolution of our highly successful PC pump, based on industry-proven progressive cavity technology. Techcon’s TS580D-MM smart controller manages the rotation of the pump rotors, delivering precise volumetric fluid metering with no guesswork required,” says Can La, Techcon product manager. “Since the fluid path of the adhesive resin and hardeners are maintained separately in each PC pump all the way to the static mixing nozzle, the likelihood of cross-contamination is significantly reduced, making clean up fast and easy.”
An optional pressure sensor is available to attach to each pump outlet for monitoring internal pressure. If the difference in pressure between the two pumps is higher than normal, the controller sends an alarm to signal the operator to check the pumps for clogging. This feature greatly reduces the likelihood of cross-contamination and damage to the pumps, a common issue among similar two-component systems.
Techcon
www.techcon.com
