Klippon Connect side-entry terminal blocks feature lateral Push In technology for fast and reliable connections. Push In technology reduces connection times for terminal blocks by up to 50 percent. Conductors can be connected quickly without a bending radius and without tools. This reduces the installation height and increases clarity, as markings and functional areas remain clearly visible even when wired.
Measuring just 3.9 inches long and 0.2 inch wide, the terminal block makes wiring more convenient even for compact terminals. An extensive range of accessories and various cross-connection options are available for any application.
“Our Push In connection technology is designed according to the compression spring principle, which means that the spring for the wire connection is held separately in the housing,” says Carlus Hicks, director of the cabinet products division at Weidmuller. “This design feature ensures a separation of mechanical and electrical functions, resulting in high conductor extraction forces to ensure maximum conductor connection.”
Weidmuller
www.weidmuller.com
