The S Jet Superior modular dispensing valve is versatile. The connection of the valve drive and the dosing needle via a ring spring limits the media contact to the dosing unit. This can be replaced quickly and at will. The modular valve is ideal for dispensing abrasive media with short processing times. Frequencies of up to 1,000 hertz with a service life of more than 1 billion cycles are possible without maintenance thanks to the piezo drive. The exchangeable dosing units print dots or lines between 50 and 3,000 microns wide. In addition, heat-conducting plates can be attached to ensure temperature control of the media.
See this company at The ASSEMBLY Show South.
Marco
www.marco-systems.com
