The eSIGN tower light features full-surface signaling, making it more conspicuous and optimizing the signal’s potential.
Thanks to LEDs and the modularity of its electrical components, different signaling modes can be produced using multiple colors, brightness levels and light effects: from a classic traffic light display to fully customized settings. Variable fill-level displays or full-surface signals can also be generated.
Applications include alarm signaling, access control, visual warnings, machine status, fill-level display and fault displays. It can also be used as an acoustic warning system. The device is equipped with a siren that can produce 10 tones. These can also be configured to suit specific applications. The siren can be combined with light effects, has variable volume options, and is easy to set up.
Depending on the variant, eSIGN can be controlled using IO-Link or configured via USB. It can be mounted on the floor, on tubes or on walls.
The signal is available with nine or 15 segments, with or without siren. IP66 or IP69k protection ensures improved resistance industrial environments. A UL type 4X enclosure guarantees resistance to UV radiation and environmental influences.
WERMA USA Inc.
www.werma.com
