Linear Actuator With Long Stroke Length
Model EC Elecylinder Slider linear actuators are designed for long-stroke, high-load applications. Widths range from 35 to 73 millimeters. Maximum stroke length is 1,500 millimeters. These compact actuators can be mounted horizontally, vertically or on the ceiling. Built-in, four-row, ball-circulating linear guides support heavy weights and large overhangs. Maximum payload for horizontal applications ranges from 3.5 to 51 kilograms. The motor can be mounted on the end or the side of the actuator. Maximum payload for vertical applications ranges from 1.5 to 25 kilograms. The actuator can be programmed with a wireless remote control.
IAI America Inc.
www.intelligentactuator.com
