Toyota Unveils New Generative AI Technique for Vehicle Design
LOS ALTOS, CA—The Toyota Research Institute (TRI) has unveiled a new way to use generative artificial intelligence to help vehicle designers come up with innovative designs more quickly.
Currently, designers can leverage publicly available text-to-image generative AI tools as an early step in their creative process. With TRI’s new technique, designers can add initial design sketches and engineering constraints into this process, cutting down the iterations needed to reconcile design and engineering considerations.
“Generative AI tools are often used as inspiration for designers, but cannot handle the complex engineering and safety considerations that go into actual car design,” says Avinash Balachandran, director of TRI’s Human Interactive Driving Division, whose team worked on the technology. “This technique combines Toyota’s traditional engineering strengths with the state-of-the-art capabilities of modern generative AI.”
TRI researchers released two papers describing how the technique incorporates precise engineering constraints into the design process. Constraints like drag, which affects fuel efficiency, and chassis dimensions like ride height and cabin dimensions, which affect handling, ergonomics and safety, can now be implicitly incorporated into the generative AI process. The team tied principles from optimization theory, used extensively for computer-aided engineering, to text-to-image-based generative AI. The resulting algorithm allows designers to optimize engineering constraints while maintaining their text-based stylistic prompts to the generative AI process.
As an example, a designer can request, via text prompt, a suite of designs based on an initial prototype sketch with specific stylistic properties such as “sleek,” “SUV-like” and “modern,” while also optimizing a quantitative performance metric. In the research paper, the team focused specifically on aerodynamic drag. The approach can also optimize any other performance metrics or constraints inferred from a design image.
“TRI is harnessing the creative power of AI to amplify automobile designers and engineers,” says Charlene Wu, senior director of TRI’s Human-Centered AI Division, whose team collaborated with the Human Interactive Driving team on this project.
By incorporating engineering constraints directly into the design process, this tool could also help Toyota design electrified vehicles more quickly and efficiently.
“Reducing drag is critical for improving the aerodynamics of battery electric vehicles to maximize their range,” says Takero Kato, BEV factory president for Toyota Motor Corp.Looking for a reprint of this article?
