Promess, Inc. has introduced a new line of lightweight press systems intended for use as end effectors in robotic assembly applications. The L-Series Robot Presses weigh up to 51 percent less than first generation Promess Robot Presses and will initially be available in sizes up to 50 kN capacities offering a 200 mm stroke and 300 mm/sec speed. L-Series Robot Presses also feature a lubrication system that allows automatic greasing of the ball nut. The press design reduces system downtime for lubrication from minutes to seconds and facilitating completely automatic greasing cycles.
Advertisement
Promess Inc.
![Servo-Press Systems from Promess Inc.](http://www.assemblymag.com/ext/resources/images/directories/eBook/Promess Inc./asbbg07224prom.jpg?1660575842)
