Hoists and cranes boost productivity, improve ergonomics and reduce damage to parts and assemblies. That’s not to say, however, that assemblers can take a cavalier attitude toward these devices. Here are some do’s and don’ts for using hoists and cranes.
  • Do read the ASME/ANSI B30 safety standard for cranes.
  • Do not lift more than the rated load.
  • Do read the hoist manufacturer’s operating and maintenance instructions.
  • Do not use a hoist that is not working correctly.
  • Do be familiar with operating controls, procedures and warnings on the unit.
  • Do not use a hoist with twisted, kinked, damaged or worn wire rope or chain.
  • Do make sure hook travel is in the same direction as shown on controls.
  • Do not lift a load unless wire rope or chain is properly seated.
  • Do make sure hoist limit switches function properly.
  • Do not use the hoist’s load-limiting device to measure the load.
  • Do maintain firm footing when operating hoist.
  • Do not use wrap wire rope or chain around the load.
  • Do make sure that slings are properly sized and seated in the hook saddle.
  • Do not lift a load if binding prevents equal loading on all supporting ropes and chains.
  • Do use hook latches wherever possible and make sure that the latches are closed during use.
  • Do not operate unless load is centered under the hoist.
  • Do make sure that the load is free to move and will clear all obstructions.
  • Do not allow your attention to be diverted from operating the hoist.
  • Do take up slack carefully, check the load balance, move the load a few inches, and check load holding action before continuing.
  • Do not operate hoist beyond limits of rope or chain travel.
  • Do keep the load or hook from swinging.
  • Do not use limit switches as routine operating stops unless recommended. They are emergency devices only.
  • Do make sure that workers stay clear of the suspended load.
  • Do not use hoist to lift, support or transport people.
  • Do warn personnel of an approaching load.
  • Do not lift loads over people.
  • Do protect wire rope and load chain from weld spatter or other damaging contaminants.
  • Do not leave a suspended load unattended.
  • Do promptly report any malfunction, unusual performance, or damage to the unit.
  • Do not allow sharp contact between two hoists or between hoist and obstructions.
  • Do inspect the unit regularly, replace damaged or worn parts, and keep records of maintenance.
  • Do not adjust or repair a hoist unless you are qualified.
  • Do use the manufacturer’s recommended parts when repairing the unit.
  • Do lubricate the wire rope or load chain as recommended by the manufacturer.
  • Do not lengthen the load rope or chain or repair damaged load rope or chain.
