Multi-Voltage Battery Charging Station
The Multi Tech charging station uses the HS-T Frequency Modulation Impulse Charging Process so batteries for cordless tools can achieve up to 15 percent more runtime per charge. This technology reconditions the cells, almost doubling the life of the battery pack and resulting in significant cost savings. The charger supports a range of battery manufacturers and charges lithium-ion, nickel-metal-hydride, and nickel-cadmium battery chemistries. The stations are available in two-bay and four-bay configurations. With voltage compatibility ranging from 3.6 to 50.4 volts, the stations use plug-and-play adapters that can be swapped to fit each manufacturer’s batteries. No voltage change is required when switching among batteries since the station automatically detects battery voltage.
Panasonic Corp.
201-392-4193
