Threaded Metal Inserts for Plastic Assemblies
When specifying for such assemblies, an essential part of the decision-making process will involve how the plastic materials or components will be attached.
Lead-free aluminum and stainless-steel inserts can be specified to address potential environmental and end-of-life recycling concerns.
The ever-increasing use of plastics in the manufacture of household appliances, compact consumer electronics, medical devices, and many other applications presents opportunities for designers to reduce the weight of assemblies and enhance end-product performance. When specifying for such assemblies, an essential part of the decision-making process will involve how the plastic materials or components will be attached.
Among the conventional options, adhesives or rivets can be appropriate candidates, but these methods will not allow for subsequent disassembly and reassembly of units, since adhesives and rivets are “fixed” and unyielding. For applications where disassembly and reassembly will be required, threaded metal inserts will serve as enabling choices.
Permanently mounted into ABS, polycarbonate, and other plastics, metal inserts ultimately provide durable and reusable threads to accept mating hardware. Inserts also create strong and sturdy joints and enable repeated disassembly and re-attachment without damaging the insert’s threads or compromising an assembly’s integrity.
When considering threaded metal inserts for an application, designers can narrow the field by evaluating the various insert mounting techniques, designs, materials, and sizes to arrive at appropriate choices.
Mounting By Design
Threaded metal inserts can be classified, in part, by how they are installed. An overview, including various insert designs within each category:
Ultrasonic inserts are installed by pressing the insert into a pre-formed mounting hole using ultrasonic insertion equipment, while simultaneously applying a high-frequency vibration. Frictional heat caused by the vibration melts the plastic surrounding the insert and allows easy insertion. When the vibration ceases, the plastic solidifies, locking the insert permanently in place.
Ultrasonic inserts are typically “thru threaded” (open at both ends) with tapered, straight, or symmetrical walls. Tapered versions are designed for use in tapered holes, allowing for rapid and accurate alignment prior to installation; straight wall inserts integrate a self-aligning lead-in providing for accurate alignment prior to installation; and symmetrical designs accommodate either straight or tapered holes and eliminate a need for orientation during installation.
Heat staking inserts are installed by pressing the insert into a pre-formed mounting hole and heating it with a thermal press to melt a small portion of the hole periphery as the insert is being pressed into the part. The softened resin then flows into the insert’s knurl pattern and hardens to form a firm bond. As with the ultrasonic inserts, these thru-threaded inserts are engineered with tapered, straight, or symmetrical walls.
Molded-in inserts are installed during the molding process and are placed in the mold cavity by core pins. When the mold opens, the core pins are withdrawn, leaving the inserts permanently encapsulated in the plastic with only the threads exposed. Since installation is performed during the molding process, there is no need for any secondary steps or special auxiliary equipment.
Molded-in types include “blind threaded” (closed on one end), which protects threads from plastic intrusion, and thru-threaded versions. Self-locking blind threaded inserts feature purposely altered threads creating a prevailing torque locking feature to prevent mating screw loosening due to vibration. With thru-threaded fasteners, the pilot diameter and undercuts allow plastic to flow into grooves, providing high pullout resistance.
Press-in inserts are installed by simply pressing the insert into a pre-drilled hole using any standard press during the production process. This method eliminates a need for applying heat or using ultrasonic equipment.
These thru-threaded inserts are especially distinguished by design variations, including a hexagonal “barbed” configuration ensuring resistance to force in both directions and exhibiting high torque-out and pullout values, slotted versions that compress to allow easy access into the mounting hole, flange-head inserts eliminating direct contact of plastic with mating parts, and inserts with straight knurls promote higher torsional resistance.
Regardless of insert type, the knurling pattern—cut or rolled by the manufacturer onto the outside of an insert—is critical, directly impacting pullout and torque-out resistances in service. (Pullout is the force required to pull the insert from the host material and torque-out is the torque required to turn the fastener in the host material without inducing clamp load on the fastener.)
As general guidelines, straight knurls (parallel to the length of the insert) offer the greatest resistance to torque, but less for pullout. (Engineered grooves between knurl bands can increase pullout resistance.) Diagonal, or helical, knurls balance resistance to forces in both directions and hexagonal, or diamond-shaped, knurls resist forces in all directions.
Micro inserts as small as 1mm in diameter and 1.7mm in length are designed for attachment applications in handheld devices and other compact consumer electronics.
Material Advances
Threaded metal inserts for plastics are manufactured from brass (the most commonly used material), stainless steel, or aluminum—and recent advances have made significant material differences for applications.
As examples, lead-free stainless steel and aluminum inserts have been introduced as alternatives to leaded brass to address potential environmental and end-of-life recycling concerns. Lead-free fasteners have been made possible by applying new materials, processes, and tool technologies without compromising fastener quality and performance.
In contrast to brass counterparts, stainless steel inserts are typically stronger and may offer better protection from corrosion, while inserts made from lead-free aluminum are approximately 70 percent lighter than brass equivalents to promote lighter designs.
Turning to sizes, inserts available in a standard product line range from about 1/8” to 9/16” in diameter and 1/8” to 5/8” in length, with unified or metric thread sizes ranging from #0-80 to 3/8-16 and M2 to M10, depending on type.
For physically smaller applications in handheld devices and other compact consumer electronics, brass and lead-free aluminum inserts have been developed as small as 1 mm in diameter and 1.75 mm in length. These tiny inserts with a symmetrical design (eliminating the need for orientation during installation) can accommodate an M1 fastener (the smallest ISO-designated M-profile thread) and can be installed with a heat staking or ultrasonic process in straight or tapered holes.
With the many types and designs, threaded metal inserts offer designers countless viable possibilities. In the event that an application may require specialized or custom fasteners, a recommended rule of thumb is to partner early in the design process with an established manufacturer. The resulting know-how and engineering support can make all the difference in successful outcomes.
