Machine builders, system integrators and assembly-line workers can use the ASI 35 leak detector in integral and localized test procedures or a combination of both. The unit uses tracer gases helium and hydrogen to detect leaks quickly and reliably, with minimum signal background and cross talk. It provides fast overall cycle times, high repeatability and maximum uptime. The detector features long-lasting iridium filaments and can operate in temperatures of up to 45 C. Remote operation is possible with the ASM Pocket app, which can be used for starting and stopping measurement cycles, autocalibration and activating the zero function. The free app is available from the Apple Store or Google Play for use on iOS and Android platforms. It connects to the detector through Bluetooth (Android) or Wi-Fi.
Pfeiffer Vacuum Inc.
www.pfeiffer-vacuum.com
800-248-8254
