Upstream Scrutiny Drives Downstream Savings
Reviewing a prototype transducer housing are Dynisco’s team members (from left) Dave Shepard, vice president and general manager; Anthony Pacitto, mechanical designer; Matt Miles, DFMA and value engineering manager; and John Biagioni, vice president of supply chain and operations. Photo courtesy Dynisco
Dynisco engineers used DFMA to revise an overly complex cover and housing component created for them by an outside firm. The revised, in-house design calls for a single, machined base made from cast aluminum. This replaces 62 individual parts and fasteners proposed by the supplier. Dynisco lowered its total cost for the part by 67 percent. Drawings courtesy Dynisco
Part interfaces are a traditional source of quality failure in products. Elimination of separate parts into single, unified assemblies helps reduce stress points and improve performance and durability. Using DFMA on a prototype transducer housing for the energy industry, Dynisco eliminated 18 parts and fasteners. A finite element analysis of the new design revealed a corresponding improvement in quality throughout the case housing, which must endure stray hammer blows in the field that occur during the routine sealing of a locknut mechanism. Photos courtesy Dynisco
Assembly efficiency is a key business metric and can tell companies a lot about their own products and those of competitors. Dynisco’s benchmarking efforts began with a DFA index comparison. The DFA index compares the theoretical minimum number of parts needed to complete the product’s functions against total operation time. From there, the company will scrutinize design of the product features, choice of materials, manufacturing methods, and tolerances. Dynisco chose to stay with higher quality, corrosion-resistant Inconel steel (product 1), rather than match its competitor’s stainless model. However, engineers found cost reductions in developing the part as a casting. This saved Dynisco approximately 2 pounds of material that would have otherwise been lost as machining waste.
Any chemist will tell you that pollutants that find their way into a river can be invisible by the time they’ve filtered downstream, even though they’re still causing damage. A similar tenet holds true for products: Decisions about how products are designed can dictate unnecessary costs during production and beyond, often without the manufacturer even noticing.
John Biagioni has spent his career scrutinizing what happens upstream. Biagioni is vice president of supply chain and operations at Dynisco, a maker of extrusion measurement and control equipment for the plastics industry.
Biagioni’s interest in the implications of product design dates back to his days at Worcester Polytechnic Institute, where he conducted a design assessment of a popular cordless drill as part of his graduate work in manufacturing engineering. His revised design eliminated fasteners, added a plain sleeve bearing, and called for a snap-together case—lowering the product’s material and manufacturing costs. The suggested changes also dramatically altered the product’s waste stream and environmental impact. The manufacturer ultimately used the design.
“People who look only to the supply chain to get cost out of a product ignore the truth that design drives cost,” Biagioni says today.
Dynisco takes that philosophy to heart. The company grades its products—which include pressure and temperature sensors, control systems, and analytical instruments—based on total cost of ownership (TCO). TCO is a holistic discipline that begins with a cost assessment of each product’s piece parts. From there, Dynisco works to ascertain the product’s total landed cost, which can include capital spent on freight, insurance, fuel charges and customs duties. But only when the picture expands to yet another level, to cover items such as the cost of poor quality, inventory carrying costs, reverse logistics, and risk factors from wage inflation to intellectual property protection, does Dynisco consider the cost picture complete.
For a company that manufactures its products in both the United States and overseas locations, such as Malaysia, such insight can be invaluable in driving operational decisions.
“The TCO model is a time-and-point snapshot that helps us decide where to build and launch a product,” Biagioni says.
Design can have a significant impact on a product’s TCO. To illustrate the connection, Biagioni relates the story of an industrial design shop that Dynisco enlisted to create specs for a small analytical instrument. Unfamiliar with the design efficiency that Dynisco practices, the outside engineers concerned themselves mostly with aesthetics—not with the manufacturing implications of their design. Their plans called for 62 parts for the single cover and housing. Dynisco is now reworking the design to cast that constellation of components into one unified part, streamlining the product’s design and minimizing the effects on downstream production and cost.
“That part is currently being sourced short-term through the design house. If I were to bring that component fully on line here, with 62 parts, think of how many suppliers I would have to potentially get,” Biagioni says. “And think of the square footage I would have to reserve, and the assembly people, stocking locations, part numbers and tolerance issues.”
Establishing the Benchmark
To help assess the TCO of its products, Dynisco benchmarks them against one another and against offerings from Dynisco’s competitors. Like the TCO methodology itself, the benchmarking process reaches far into the company, touching nearly every department.
The process begins with performance tests on Dynisco’s and competitors’ products. Next, a team led by Matt Miles, Dynisco’s DFMA and value engineering manager, tears down each of the competitive products, analyzing the design part by part to create a bill of materials.
When the benchmark analysis is complete, the team analyzes each product using the Design for Manufacture and Assembly (DFMA) methodology, which calculates the costs of the parts and the assembly processes Dynisco uses to turn them into products. DFMA is governed by two complementary software tools from Boothroyd Dewhurst Inc. The Design for Assembly application helps engineers assess the structural efficiency of their designs and consolidate parts to improve efficiency and cost. The Design for Manufacture tool suggests alternative material choices and process improvements to the original design.
“We wanted to analyze what types of material the competitors used, how much they used, and how much machining was involved, compared to ours, so we could capture that dollar value,” Miles explains. “We found some examples where eight pounds of raw material were used, and you’re machining away more than 75 percent of it.”
Dynisco left no stone unturned during the benchmarking exercise, even analyzing the way subassemblies were mated during production, determining how pieces were bonded and what kinds of soldering joints were used. “We looked at everything,” Miles says. “With the help of the software we could project the total assembled cost of a competitor’s unit.”
To validate the DFMA tool to their coworkers, Biagioni, Miles and the team recorded each product’s DFMA score, part count and related metrics in a spreadsheet. They then shared the data with the benchmarking team, which included vice presidents, product managers, operations personnel, supply chain practitioners and engineers. Miles says a large benchmarking team was necessary.
“The impacts of the cost of ownership are felt throughout the company,” he explains. “An engineer’s design decision will impact not only the design, but reparability out in the field, as well as the procurement of parts and cost. That’s why we brought in so many stakeholders.”
Dynisco gathered the team of 16 in a conference room for a day, scrutinizing each assembly, passing parts around, and reviewing the DFMA attributes and data. At the end of each product review, the team addressed such critical questions as “Where do we go from here, and how do we make our product better?”
The diversity of participants led to a cascade of ideas. The team considered new assembly techniques, methods of consolidating parts, and alternative materials that would streamline costs while maintaining quality and function.
“Getting people from the different departments all together in one room, you really open up communication,” Miles says. “The energy we created in that environment, it’s powerful. You come out of there and you have everybody in the room charged up about redesigning the product.”
Funding Future Growth
This type of analysis has also paid off elsewhere in the company, on a different line of products that underwent a ‘refresh’ exercise. With the help of the DFMA tool and the ingenuity of its benchmarking team, Dynisco managed to shrink more than 1,000 component part numbers (available for customization) to a standard core of less than 200. Uncovering the hidden inefficiencies in its products and processes has helped the company reduce its suppliers, minimize raw material costs, cut down on assembly complexity, and conserve manufacturing resources. And it has done so within a relatively small window of change, given that DFMA methodologies have been in place for only two years.
Biagioni subscribes to the notion that 80 percent of a product’s final cost is governed by its initial design. This means that, for products already in the field, Dynisco can reduce current product generation costs up to 20 percent using DFMA benchmarking and the subsequent improvements found through sourcing decisions, better material and process selection, and applying lean manufacturing tools. While the company has its long-term savings goal set very high, the changes made to date by its teams have had a profound impact on Dynisco.
“We’re...shooting for seven-figure savings just this year,” Biagioni says.
In some companies, such efficiency gains would have executives eyeing layoffs. Dynisco takes another tack. It uses the savings from streamlining existing products to help fund new product development, allowing the company to keep headcount steady even as its product portfolio expands.
“We don’t have to hire or scale at the same rate as our part-count growth,” Biagioni says. “That’s a significant lever. We’re doing more with less in terms of our working capital.”
As for how it manages the TCO of those new products, Dynisco again turns to the DFMA software—keeping in mind the 80/20 rule. During its stage-gate process, the company assigns each new design a baseline DFMA index, then sets cost and index targets for the product.
“This is a hugely important step,” Biagioni says, “because it is restructuring the way our business will run three and five years down the road.”
The manufacturer has added a sixth step to its five-step stage-gate process. Six months after a product’s launch, the team performs a TCO checkup to assess cost structure, sales and other metrics. That’s where the iteration begins, Biagioni says. “Maybe we’re paying more for freight, or we’re paying less for freight. Or maybe we had a yield issue.” This six-month checkup brings old assumptions in for new analysis, allowing the company to adjust accordingly.
Top-Down Support
Dynisco’s benchmarking and design philosophy would be impossible without one key element: executive support.
“Our initiative with DFMA is very strongly supported throughout our executive team,” Miles says. “That makes my job easier, having their buy-in.”
Biagioni, too, is grateful to be part of an executive team that bases decisions on a rational view of product costs, rather than simplistic theories of cost savings.
“I’ve always been a proponent of just doing the math,” he says. “I think that by making sourcing decisions based on logic, vs. whatever a third party happens to be saying at the time, makes a big difference. People have to look at the TCO. Not the myopic view of the plant level, but really the total cost.”
While Dynisco hasn’t perfected the TCO model yet—amorphous elements such as intellectual property risks, wage inflation, and workforce language barriers can be hard to nail down in financial terms—it has managed to improve its costing IQ.
“If a controller were to give you the answer to where to make the product, they would say that the part is cheaper to make in Malaysia, because they’re going only on part cost,” says Biagioni. “That’s why you have to elevate the discussion.”
And discussion is one of the things that made the benchmarking process at Dynisco such a success.
“Part of what we’ve done with this process,” Miles says, “is we’ve promoted the conversation across the board. And I think it has worked well.”
What hasn’t always worked well in the larger manufacturing world is trying to squeeze cost from the supply chain without a full appreciation of a product’s life cycle. Executives who look to save 5 percent downstream—by leaning on parts suppliers or renegotiating logistics contracts—are missing the real opportunity for savings, Biagioni says.
“That’s an archaic way of thinking about it. You need to go back to design. Design is what does it,” he says.
Because whatever you release upstream inevitably finds its way downstream.
For more information on DFMA, visit www.assemblymag.com to read these articles:
- Product Design: DFMA vs. Lean.
- DFMA Cuts Costs Up Front.
- Successful Design for Assembly.
