There are multiple ways to create the master signature for signature analysis. The methods range from simple to quite complex, depending on the process requirements. Techniques include teaching a single part cycle, in multiple cycles or in a max/min signature range.
“There are multiple ways to create
your master signature, varying from simple to quite complex,” says Glenn Nausley
vice
president-general manager of Promess Inc., which is a supplier of signature analysis
products. “The method used depends on the
process requirements.” Some techniques include:
*Teaching
a single part cycle. This method works very well for simple processes with very
repeatable signatures. Teach in one good part. Every subsequent part should
follow that signature plus or minus some allowable tolerance. If the signature
is different you know the process did not follow the norm.
*Teaching
in multiple cycles and creating the signature master based off of the
information gathered during this run.This is sometimes the best method when a
process has a large amount of allowable variation and a single cycle teach will
not adequately represent the process.
* Teaching
in a Max/Min signature range.This method works well when Max/Min conditions can
be easily created in a test or mastering run.
* Master
signatures can also be created using historical part data. Historical data is
collected and analyzed and master signatures are created based on this
information.
*Master signature can be edited manually when
required to ensure they match the test criteria.
