The center’s services concentrate on four areas:
- Enabling technologies and expertise.
- Design and supply of special production equipment.
- Improvement methods and tools for the product creation process.
- Expertise in overall process optimization.
When it was time to look for a new dispensing system, the center turned to Asymtek (Carlsbad, CA) and purchased its M-2000 high-speed dispensing system with noncontact jet technology. Only a short time after installing the new dispensing equipment, the center immediately experienced more than a 50 percent increase in unit throughput on their surface mount assembly line for one of the products manufactured at the facility.
The M-2000 dispensing system delivers high speed and accuracy. For surface mount adhesive dispensing, the system is suitable for high-volume, production-critical applications that must operate continuously with minimal operator intervention.
In addition to the improved unit through-put and yield, the center’s engineering team discovered other benefits. The system’s DispenseJet head reduces the time previously required for programming mechanical standoff positions. The noncontact dispense head eliminates Z-axis motion during dispensing, virtually eliminating the need for height sensing. Maintenance is no longer an issue.
“After 2 or 3 days of operation,” states Mike Tong, manufacturing engineer, “we remove the nozzle, clean the needle, purge a slight amount, and we’re off and running again.”
Fluidmove for Windows NT software provides quick and accurate programming control. It can be quickly and effectively programmed for maximum dispensing yield. CADImport software, used in conjunc-tion with Asymtek’s Fluidmove, quickly allows Philips to create a Fluidmove program using existing CAD data. Once a component library has been set up, process engineering can write a typical dispensing program off-line in a matter of minutes. Following the M-2000 installation, the adhesive dispensing process is no longer a bottleneck. In fact, it now paces the rest of the line.
For more information on fluid dispensing systems, call Asymtek at 760-431-1919, visit www.asymtek.com or Reply 1.
