Pierson Cheng
Pierson Cheng
Automotive Industry Manager
TRUMPF Inc.
Pierson Cheng has been with Trumpf his entire career. He began at the company’s office in Taicang, China, in 2005. Nearly nine years later, he transferred to Trumpf’s office in Plymouth, MI, where he assists automotive manufacturers with laser welding, cutting and marking applications. He has a master’s degree in business administration from the University of Michigan and a bachelor’s degree in optics from Sun Yat-Sen University in Guangzhou, China.
WORKSHOP #2 | Fastening & Joining: New & Alternative Methods
Lasers for Lightweighting
Lasers are creating new possibilities to shape and join lightweight materials. In particular, lasers are being used to assemble aluminum doors, window frames, hoods, trunk lids and other parts that require a Class A finished surface. Lasers are advantageous in these applications because engineers can carefully control and focus the energy directed at the assembly. Joints produced by arc welding or resistance spot welding may require finish grinding; joints produced by laser welding need little or none. Another advantage of laser welding is its ability to produce continuous seam welds, parallel welds, and C- or S-shaped welds. That can make for stronger welds and allow engineers to use thinner materials in their designs. In this presentation, you’ll learn how automakers like Ford, GM and BMW are using lasers on their assembly lines.
Learn More
ASSEMBLY Show Speakers
ASSEMBLY Show Agenda
