President
PressLock Technologies
Byron Selorme is president of Press Lock Technologies, a manufacturer of presses and riveting equipment in Hamilton, Ontario, Canada. Prior to starting Press Lock in 2020, Selorme served as director of engineering and product development at Norlok Technology Inc., a manufacturer of sheet-metal clinching equipment in Brantford, Ontario, Canada. He holds a degree in mechanical engineering technology from Mohawk College in Hamilton, Ontario, Canada.
As engineers incorporate a greater mix of materials into their product designs, two joining methods—clinching and self-pierce riveting—are gaining attention as alternatives to spot welding. Self-pierce riveting (SPR) is a cold joining process for fastening two or more sheets of material by driving a rivet through the top sheets and upsetting it, under the influence of a die, into the bottom sheet without breaking through it. The process can join high-strength steel, galvanized steel, aluminum, plastics and composites. In clinching, a punch and die are used to plastically form a mechanical interlock between metal sheets. The process can join metal sheets of different thicknesses or materials. It can even be used on stainless steel. This presentation will cover everything you need to know about these two joining processes.
