Programmable Rotary Tables are used to position components that need to be rotated in specific, very accurate degrees of rotation so that manufacturing operations can be performed.
On horizontal rotating applications where high inertias coupled with the requirement for high accuracy come into play, geared solutions may not be such a great solution.
These units are exposed to the high acidity from hot peppers
and the daily barrage of harsh chemicals used during the washdown process to clean the machines to prevent bacteria buildup.
When determining the proper linear transfer system there are some key factors that will help determine what is appropriate for your specific application.
We are presenting a new version of our well-established LFA linear transfer system specifically designed to meet the requirements of modern manufacturing.
Motion Index Drives, Inc. was tasked with designing, engineering, and manufacturing a linear transfer shuttle that is a cross between a robot transfer unit and a tool tray transfer unit.
Motion Index Drives designed and manufactured this NEW custom Precision Link Conveyor for our customer in Automotive manufacturing to accommodate their application requirements.
