content provided by balluff
Magnetostrictive linear position sensors are the dominant technology for hydraulic cylinder position feedback. They are preferred over alternatives due to their high accuracy, wide variety of electrical interfaces, signal stability across temperature variation, wear-free operation, and tolerance of shock and vibration. This makes them popular in a wide range of industrial hydraulic applications for smart cylinders and servo-hydraulic systems.
Despite the inherent ruggedness of the sensors, adverse operating conditions in industrial applications can stress and sometimes exceed the survivability of standard product offerings. This can result in premature sensor failure and/or shortened preventive maintenance intervals.
Fortunately, specialized product variations can deliver a longer and more reliable service life under adverse operating conditions. And best practices for installation and mounting can also help alleviate exposure to the most damaging effects of application environments. Read on for recommendations on ways to enhance sensor reliability and extend life expectancy in a range of common industrial settings.
Heat
High temperatures are a fact of life in many industrial processes, such as the steel-making process, with ambient environments that can destroy electronics. Solid-state electronic components are stressed by elevated temperatures and can fail at much higher rates than they would at room temperature.
Ambient heat can affect sensors through three mechanisms:
  1. Conduction (direct transfer from the mechanical mounting)
  2. Convection (circulating hot air impinging on the sensor housing)
  3. Radiation (line-of-sight infrared heating of the sensor housing at a distance)
Three Steps to Protect Against Heat
Evaluate what can be done to reduce the sensor’s exposure to heat. To combat conduction, try to locate the sensor as far as possible from the heat source. If practical, install insulators to isolate the sensor mechanically from direct contact with hot objects. Convection can be alleviated by installing guards or deflectors to block hot air from the sensor housing. Often these same guards will aid in blocking radiating infrared energy as well, keeping in mind that with prolonged exposure energy will get through and be re-radiated on the back side. If the heat source is intermittent, such as a passing red-hot slab of steel on rollers, the heat only needs to be blocked for a few seconds to protect the sensor.
Next, be sure to specify the right kind of cylinder position sensor for hot applications. Standard cylinder sensors typically have a maximum specified temperature rating of 75° C (167° F), but enhanced variants can withstand up to 100° C (212° F). Don’t forget that many standard cable materials will melt or break down quickly at higher temperatures, so its important to use specialized cable jacket materials such as PTFE that can withstand up to 200° C (392° F). Another strategy is to insert a double-ended cordset between the sensor and the home run cable. If this short sacrificial cable becomes damaged, it can be quickly replaced without the time-consuming task of pulling a new home run cable.
Finally, it may be that the hot environment is just too severe for any electronics to survive for very long. In these cases, place the sensor in a protective enclosure designed for air purge or water jacket cooling.
Cold
In some industries, particularly oil and gas, operations are conducted in arctic or subarctic regions where temperatures can fall to -40° C (-40° F) or below. At these temperatures, polymers intended to remain pliable such as O-rings, gaskets, cable insulation and outer jackets, and sensor element damping materials can become brittle. Semiconductor materials start to lose conductivity and circuits can behave unpredictably.
Special hydraulic cylinder sensors are available that are designed to operate as low as -50° C (-58° F). These products feature polymer materials designed and specified to operate down to those temperatures. To combat electronic malfunction under these conditions, the manufacturer may specify that power should remain applied to the electronics at temperatures below -40° C (-40° F). The heat dissipation of the electronics themselves keeps them within normal operating limits.
Physical Impact
Standard cylinder position sensors are typically constructed with a stainless steel flange and an extruded-aluminum housing secured by a couple of screws. In cases where the housing may be exposed to physical impact, such as a falling log in a lumber mill, standard sensors can easily be damaged.
There are three basic approaches to improve survivability to amechanical impact:
  1. Guard. Many cylinder manufacturers can provide accessory guards for cylinder sensors. These are essentially lengths of steel pipe attached to the cylinder end cap that cover the sensor. A disadvantage is that they often have to be removed in order to service the sensor, and are mistakenly or intentionally left off after the service procedure, leaving the sensor vulnerable to impact.
  2. Embed. Compact cylinder sensors can be embedded inside the cylinder, so the rugged cylinder itself protects the sensor from damage. These sensors are usually called embeddable types. Often installed in welded cylinders for mobile hydraulic applications, they are entirely suitable for stationary industrial applications as well.
  3. Upgrade. Cylinder sensors with especially robust housings provide an upgrade path from standard types. Thread-in types are available for retrofit applications, as are even more robust bolt-in types (the cylinder must be prepared accordingly by the cylinder manufacturer).
Shock
Many industrial hydraulic cylinder applications involve large forces and heavy loads that can generate substantial amounts of shock under normal and/or abnormal conditions. Shock is defined as a rapid acceleration or deceleration transient and can occur axially or radially relative to the cylinder position sensor depending on the application.
Typically, hydraulic cylinders deliver or absorb axial shock along their linear axis of operation. Trunnion-mounted cylinders often generate radial shock, for example infeed rollers coming down on a log in a lumber mill, as they pivot in their mounting.
If an application is suffering from a high sensor failure rate due to shock, the first step is to determine if the hydraulic control system can be optimized to reduce the generation of shock. For example, can the motion control profile be tuned to deliver less violent acceleration or deceleration? Can the motion profile be adapted to enable softer starts and stops? The key to reducing shock is to reduce the peak amplitude of the G-forces and/or stretch out the time of the transient so that the acceleration gradient is less severe. A 100 G peak shock delivered over 6 milliseconds is less severe than a 100 G peak shock delivered within 3 milliseconds.
Once the application has been evaluated and optimized to minimize shock generation in the first place, the next thing to do is look for sensors with enhanced shock specifications. The minimum specification should be 100 G, with preference given to products rated up to 150 G. For even more severe applications, consult the sensor manufacturer regarding specially engineered versions.
Don’t forget that the extra mass of a sensor-mounted quick-disconnect connector can sometimes be a vulnerability under severe shock. Combat broken connectors with so-called “pigtail” or “inline” connectors that have a flexible cable coming out of the sensor that goes to a quick-disconnect a few inches or feet away.
Vibration
Vibration is also ever-present from motors, rollers, and moving materials. When combined with heat or thermal shock due to ambient temperature fluctuations, vibration can rapidly age electronic components and internal connections, leading to early failure.
Vibration mitigation can be difficult or infeasible for cylinder position sensors in most cases, so enhanced sensor design is required to improve sensor survivability. An effective design and testing methodology for achieving sensors that can withstand extended exposure to vibration is called HALT or Highly Accelerated Lifetime Test.
Products undergoing HALT are subjected to accelerated aging during their development in order to uncover weak points early so that they can be eliminated. The samples are subjected to ultra-low and ultra-high temperature soaking as well as rapid, extreme temperature changes. The temperature range can extend from –100 °C to +200 °C with a temperature gradient of up to 70 K/min. This is followed by vibration testing up to maximum levels of 50 G. The repeated cycles of temperature and vibration testing is continued until the test unit finally reaches its limit and is destroyed. The goal of the design team is to extend the period of time until ultimate failure as long as possible.
Look for sensors with excellent specifications for vibration. EN 60068-2-6 provides a good standard of 20 G with a frequency sweep from 10…2000 Hz.
Liquid Ingress
Applications where there is a continuous exposure to liquids like water, coolants, and oils will eventually overcome the housing gaskets found on many standard sensors rated to IP67 or less. Standard sensors are designed to withstand liquid ingress for a specified period of time but are not rated for constant immersion or exposure to wet conditions.
The photo below was taken in a rolling mill and shows a blue plastic cover installed over a position sensor in an attempt to keep falling water from entering the sensor housing.
As always, mitigation is an effective approach; try to locate sensors out of wet areas and/or provide effective splash guards. When exposure to liquids can’t be avoided, select sensors with enclosures rated IP68 or IP69K. IP68 means that the manufacturer is offering immersion protection beyond IP67 (consult the manufacturer for details) and IP69K means that the sensor is rated for pressurized washdown. Some sensor housings are hermetically welded to provide a 100% leak-proof assembly.
Be aware the cable can represent a vulnerability to liquid ingress. If the cable jacket is cut and liquid enters, it can travel inside the cable and end up inside the sensor housing. It’s a good idea to install protective tubing over the cable to ensure that it remains intact in case of incidental contact or abrasion in the application.
Corrosion
Chemicals present in the environment can lead to problems with sensor housing corrosion. In particular, aluminum housing components can be compromised by prolonged exposure to corrosive elements. Common examples include road salt, seawater and airborne sea spray, and acidic food juices, among other contaminants.
Here is an example. On the failed unit (right), the red RTV silicone sealant was a plant maintenance attempt to protect the sensor. Despite the addition of external sealant, acidic water worked its way under the silicone and became trapped against the lower part of the housing. When the sensor failed and was pulled out for analysis, peeling back the layer of sealant revealed several holes that had been eaten through the aluminum housing. The recommended housing material to alleviate most concerns about corrosion is stainless steel. For typical conditions, standard grades 303 and 304 stainless steel are sufficient.
In areas where salt or seawater is present, stainless steel grade 316L is preferred. Standard stainless steel is protected from corrosion by a thin layer of chromium III oxide that forms at the surface. Some ions, such as chloride ions found in salt water, can strip away this protective layer and expose the underlying steel to corrosion. 316L stainless steel is formulated to resist attack by chloride ions.
High Cylinder Pressure
Standard cylinder position sensors are rated for hydraulic pressures up to 600 bar / 8700 psi. However some compact mobile hydraulic systems run at higher pressures, as do heavy-lift systems used for example in civil engineering projects. Special high pressure cylinder sensors are available rated up to 1000 bar / 14,500 psi to ensure that the system remains safe and operational at elevated system pressures. Be aware that the outer diameter of the pressure tube surrounding the sensor element is necessarily larger--12.7 mm vs. standard units at 10.2 mm--so it requries a larger gun drill in the cylinder rod and a target magnet with a larger inside diameter. Also keep in mind that the hydraulic port size of M22x1.5 is larger vs. the standard ¾”-16 UNF or M18x1.5. These differences in mechanical details need to be communicated to the cylinder manufacturer at the time of specifying and ordering, or a standard sensor-prepped cylinder might be delivered.
Redundancy and Rapid Repair
To combat the consequences of sensor failure in critical applications, system designers have a number of options to help keep operations running despite a failure, or to get failed units back on line quickly. Here are three common approaches:
  1. Redundant sensors. These have two, three, or even four sensors operating in parallel. When one sensor fails, the others continue functioning. In schemes involving more than two sensors, voting in the controller can be used to determine which sensors are delivering valid position signals and which one is out of synch with the others. Typically, the primary sensor will be installed in the cylinder. The redundant sensor or sensors will be installed externally in mounting brackets designed to hold the sensor in place and connect the target magnet to the moving portion of the equipment.
  2. Redundant sensor outputs. Specialized cylinder position sensors are available with two or three entirely separate position sensors contained in a single sensor enclosure. Each sensor has its own separate connector. The advantage is ease of installation in a standard cylinder port without the need for external mounting and brackets. A potential disadvantage is its dependency on a single target magnet inside the cylinder and a single pressure tube. Loss of the magnet or damage to the pressure tube can take down all channels together; however in practice such an occurrence is extremely unlikely.
  3. Rapid repair. Sensors are available with modular electronics that can be quickly removed in the event of failure, while leaving the pressure tube in place in the cylinder. This eliminates safety concerns such as hot oil spilling onto maintenance workers, loss of hydraulic fluid and resulting clean-up/containment, and the potential for entry of contaminants and air into the hydraulic system.
Another rapid repair strategy: install a sensor with redundant outputs, but connect only one channel for control. Cover the unused connectors to protect them while not in use. If the control channel fails, simply move the connecting cable to another channel and resume operations. The sensor unit with a failed channel can then be scheduled for removal and repair during a planned preventive maintenance
Conclusion
You don’t have to put up with premature or frequent cylinder sensor failure due to adverse conditions in industrial applications. With careful attention to the application conditions and by matching the sensor to application requirements, you can alleviate or eliminate issues related to sensors failing. When failures do eventually occur, strategies such as redundant sensors, sensors with redundant outputs, or sensors designed for rapid repair can help maintain production uptime.
