Wire Processing Products Tester Measures Leakage at Low Voltage John Sprovieri January 29, 2024 A new option for the HVX line of harness and cable testers permits leakage measurements of 10-gigaohm isolation at a test voltage of 100 VDC. Read More
Wire Processing Products Connectors and Terminals for Alarm, Security Applications John Sprovieri January 28, 2024 ETCO produces a wide range of electrical connectors and terminals for every requirement in an alarm and security system, including PCB and Wi-Fi components. Read More
Wire Processing Products Side-Entry Terminal Blocks John Sprovieri January 27, 2024 Klippon Connect side-entry terminal blocks feature lateral Push In technology for fast and reliable connections. Read More
Wire Processing Products Machine Automatically Cuts, Strips Wire John Sprovieri January 26, 2024 The E400 automatically cuts and strips wire ranging from 26 to 6 AWG and cable ranging from 0.8 to 12.5 millimeters in diameter. Read More
Wire Processing Meeting the Challenges of KSK Wire Harness Assembly Austin Weber January 25, 2024 Customer-specific production requires a unique mindset.Read More
Copper Will Remain a Key Material in EVs Austin Weber January 10, 2024 Copper will remain a critical component in electric vehicles.Read More
Yazaki and NEC Use AI to Control Wire Harness Assembly Robots Austin Weber January 5, 2024 TOKYO—Engineers at Yazaki Corp. and NEC Corp. are using artificial intelligence technology to generate motion plans for wire harness assembly robots.Read More
New Process Improves Copper Wire Conductivity Austin Weber January 2, 2024 Adding a small amount of solid carbon to copper can boost its ability to conduct electricity. Read More
Processing High-Voltage EV Cables Nick Liu December 14, 2023 Applicators, crimping machines and other types of high-voltage cable and wire processing equipment play key roles in electric vehicle production. Read More
Wire Processing Harness Tester Indicates Distance to Short or Break October 13, 2023 The CableEye cable and harness test system can now show engineers the distance to a short in addition to the existing distance-to-break capability. Read More
