Roller bearings are a critical component of modern machinery. When the bearing is in operation, the cage must be able to withstand centrifugal force, shock and vibration, especially with complex loads rotating at high speeds.
According to the Environmental Protection Agency, commercial airplanes and business jets contribute 10 percent of transportation-related carbon emissions in the U.S., and account for three percent of the nation’s total greenhouse gas (GHG) production.
OTTAWA, Canada—Pleora Technologies has introduced a new embedded interface that transmits low latency GigE Vision video and data at 10 gigabytes per second (Gbps) over flexible Ethernet cabling.
When dispensing form-in-place gaskets—for example, on the die-cast housing of an automotive control unit—it’s important to apply the material precisely along the contour of the part. On the housing, the contour runs partly in a straight groove, partly around corners and screw locations and partly along various radiuses. In the area where the plug housing will be installed, the material often must be applied on a ramped surface. All this makes consistent, gap-free dispensing difficult.
The new DC803 Dispensing Cell from Scheugenpflug GmbH promises to make the process faster, easier and more reliable.
Initiated in 2004, the Assembly Plant of the Year award showcases world-class production facilities in America and the people, products, and processes that make them successful.
